Hi Members
I saw at my Admin log that there are again some Members who got the ''wrong password'' message.
What to do about that? first nothing is wrong with your pc or our Forum.
Look here and find out how to perform a succesfull login:
Hello All, on our forum log we have seen some members who got their ''Password incorrect'' to prevent this from happening read the following note pls.
LOOK AT THE RED OVAL(picture above)
Note:
When logging onto W7NI enter your username, then your password,
When Your Username and psw is already shown: empty out the Black Dots (see the Blue Oval) and type your psw again(you'll see NEW Black Dots) just hit ENTER and when Explorer ask you to remember SAY
NO just Enter again and your Login goes fine., in the next box the default sign in is "FOREVER” Please leave this set to “FOREVER” With this configuration you will NOT have to sign in every time you visit our forum. Once signed into the forum Bookmark us and your should be set.
For the p.m readers only:
Above I have included the log in box filled in for your convenience,
as you will see “FOREVER” is encapsulated in the red oval.
LOOK AT THE BLUE OVAL(picture above)
Register problems:
When you are a Guest and want to register take a look at the pic above and empty out the Black Dots (see the Blue Oval) and type your psw again(you'll see NEW Black Dots) just hit ENTER and when Explorer ask you to remember SAY
NO just Enter again and your registration goes fine.
Following this example your Register and Log In problems should be over
Be sure to use a password you will remember easily!
Note: alot inlog and register problems occur because your Browser stores psw's and messes up! so empty out your (Explorer) Cache and Cookies,
How do I clear my web browser's cache and cookies? Each time you access a file through your web browser, the browser caches (i.e., stores) it. In this way, the files (including any images on the page) do not have to be newly retrieved from the remote web site each time you click the Back or Forward buttons. You should periodically clear the cache to allow your browser to function more efficiently.
If you do not see instructions for your specific version or browser, search your browser's Help menu for "clear cache".
See below:
Internet Explorer 8
1.From the Safety menu in the upper right, click Delete Browsing History... .
2.Check Temporary Internet files, Cookies, and History, and then click Delete.
Internet Explorer 7
1.From the Tools menu in the upper right, select Delete Browsing History.
2.Next to "Temporary Internet Files", click Delete files... .
To delete your cookies, click Delete Cookies.
3.Click Close, and then click OK to exit.
Firefox 3.5 for Windows
1.From the Tools menu, select Clear Recent History... .
2.From the Time range to clear: drop-down menu, select the desired range; to clear your entire cache, select Everything.
3.Click the down arrow next to "Details" to choose what history elements to clear (e.g., check Cookies to clear cookies). Click Clear Now.
Firefox 3 for Windows
From the Tools menu, select Clear Private Data... , and then check Cache and Cookies. Click Clear Private Data Now.
Safari
1.From the Safari menu, select Reset Safari... .
2.From the menu, only select Empty the cache and Remove all cookies, then press Reset.
Firefox 3.5 for Mac OS X
3.Click the down arrow next to "Details" to choose what history elements to clear. Click Clear Now.
Firefox 3 for Mac OS X
1.In Firefox, from the Tools menu, select Clear Private Data.
2.Make sure Cache and Cookies are checked, and then click Clear Private Data Now.
Tech Support
