Author Topic: A utility so simple you have to wonder why it's not shipped with every Mac  (Read 984 times)
If you use an external display with your Mac, you need to check this out.
I'm a big fan of using external displays with my Macs. I have a 32-inch display on a long monitor arm that's connected to my MacBook Air. But my wife pumps it up in a big way by attaching a 40-inch TCL Roku TV as her main Mac mini monitor.
As long as you don't have broadcast studio-level visual demands, these add-on monitors and TVs are great. They provide ample screen real estate, and they're far less expensive than either Apple's $1,599 Studio Display or $5,000 Pro Display XDR.
As someone who likes to hang displays off of extra-long Ergotron monitor arms, I've found that many add-on monitors are reasonably lightweight and therefore quite practical. My 32-inch monitor is 10.65 pounds. Apple's smaller 27-inch model Studio Display weighs 13.9 pounds. If you wanted to mount the Pro Display XDR, you'd have to spend a whopping extra $1,000 Apple tax for a VESA mount adapter, and it would still be 16.49 pounds -- a bit much for a long monitor arm.
But there is one problem: you can't easily adjust the display brightness. On my Westinghouse monitor, you have to find a button on the back of the monitor, hit a few menu items, and then toggle another set of buttons (also on the back of the screen) to adjust brightness.
For my wife's Roku TV, it's possible to control brightness by hitting the menu button on the Roku remote. But it's not possible to control brightness based on input. So if she wants to dim the Mac mini's display, she's also making Netflix and HBO Now dimmer as well. Nobody wants to watch an extra-dim House of the Dragon.
Introducing MonitorControl Lite
Fortunately, there's a free app in the Mac App Store that completely solves the problem. It's called MonitorControl Lite. Once you've installed it, you too will see the light (or not as much, depending on your preference).
It lives on your menu bar, and lets you control all the monitors on your system.
While the name of the app has "Lite" in its title, the program has a relatively robust set of controls and settings. You can decide how you want settings to be displayed and restored.
You can decide how you want the controls to be displayed.
You can define keyboard shortcuts.
You can even set options based on individual monitors or screens.
As the light levels in your room or office change throughout the day, you can keep your eyes comfortable by changing the screen brightness. Most of us would just live with the eye strain before fumbling around behind our screens two or three times a day to find buttons and toggle inconvenient menus. It's really nice to be able to prioritize the comfort of your eyes and adjust the screen with such convenience that you actually do it whenever you need to.
The bottom line is simple. This app is worth considerably more than you have to pay to get it. It does the job; it makes dimming convenient and flexible. It's an ideal example of some of the small utilities available for Macs that very much enhance the user experience.
