We’ve been hearing about the 16-inch MacBook Pro for quite some time, and a lot of reports and concepts have surfaced over what it might actually be. Well, most of the aforementioned agree that Apple will likely retain the chassis of its 15-inch model, but reduce the screen-to-body ratio, by narrowing down the bezels. This would allow Apple to fit in a larger display in the same form factor.
We no longer have to wonder. The upcoming 16-inch MacBook Pro is pictured above. While not a high-quality press render, the image does indeed originate from Apple. Discovered by Macg, it is found inside the macOS Catalina 10.15.1 beta 2 build.
