Author Topic: PC and PC Component Terms  (Read 1162 times)
« on: August 25, 2018, 04:51:42 AM »
Keeping up with the latest PC technology is difficult, but it’s overwhelming if you don’t understand all the jargon you encounter when reading articles and spec sheets.
From CPUs to GPUs and their inner workings, to motherboards and their varying parts, different display technologies and types and vendor-created phrases, you can wind up in tech terminology turmoil.
That's why we have developed this handy glossary. With the information below, you can learn the meaning of--or refresh your memory on--commonly used, but often confusing, tech terms.
We’ll be adding to the glossary over time. If you find a term that leaves you scratching your head, let us know in the comments below, and we’ll be sure to define it for you.
Index
2K
4K
5K
720p
1080p
APU
BIOS
Bus
Cache
Capacitor
Chassis
Chipset
Clock speed
Core
CPU frequency
DIMM slots
Delidding
Discrete GPU
DRAM
FOV (field of view)
FHD
Full HD
GPU
GPU Boost
Graphics card
Heatsink
HD
Hyper-threading
IHS (integrated heat spreader)
Integrated GPU
IPC
IPS
Motherboard
Motherboard firmware
N-key rollover
NVMe
OLED
PCIe
QHD
RAID Controller
RAM
Ray tracing
SRAM
Socket
SLI
Simultaneous multithreading
SSD
TDP
Thread
TPM header
TN
UEFI
UHD
Ultra HD
VA
Video card
VRM
WUXGA
WQHD
« Last Edit: August 25, 2018, 05:24:40 AM by javajolt »
