Author Topic: Full Build 2018 session list now available  (Read 801 times)
« on: April 25, 2018, 02:35:36 AM »
Microsoft's Build 2018 developer conference kicks off in less than two weeks now, and as we reported would happen a couple of weeks ago, the full session schedule is now live. You can use the Microsoft Build Schedule Builder to mark down sessions that you plan to attend.
The mobile Build applications haven't been updated just yet, but if you've still got the Build 2017 apps on your phone, those are the ones that should see an update. If not, you'll have to download the app from your respective app store whenever Microsoft decides to release those.
In the web app, you can filter the sessions by day, session type, topics, product, tags, keywords, learning paths, level, and speakers. In total, there are 434 sessions that will take place during the three-day event.
The Schedule Builder is an invaluable tool for keeping track of sessions, as it can get a little crazy out on the show floor. If this isn't your first Build, then you know this, but if it is, you should definitely check it out.
Moreover, Microsoft says that if you're not one of the 6,000 attendees, you'll be able to live-stream all of the sessions that are going on. If you want to check out the Build 2018 Schedule Builder, you can find it here.
