Author Topic: How to record your screen using the built-in screen recorder on Windows 10  (Read 447 times)
Windows 10 comes with the new Xbox app which packs support for Game DVR. If you’re wondering if there’s any way to record your Windows 10 screen with any built-in recorders on Windows, you’ll be glad to know that there’s one now on Windows 10.
To record a video, just hit the Windows Key   G on your PC when any window is open and the Game DVR menu should pop-up. After that, click on the checkbox “This is a game” and you’ll be navigated to the simple interface where you can capture a screenshot and record your screen. Just hit the red record icon and it’ll start recording your screen.
It’s worth noting that the built-in screen recorder can’t produce high-resolution videos. Here’s an example:
If you’re looking for a free tool which lets you record high-resolution videos, checkout this tool.  Nonetheless, tell us what you think of the built-in recording tool on Windows in the comment section below!
source:microsoft-news│via: TechAU
