Author Topic: Ear Trumpet is a new app for Windows 10 which brings better volume control  (Read 1530 times)
With Windows 10, Microsoft introduces a new volume control. To be honest, the new volume control on Windows 10 is pretty bad currently and does not let you change the volume for each apps – which is pretty disappointing. Thankfully, there’s a new app for Windows 10 developed by Windows enthusiasts Rafael Rivera and David Golden. The app, dubbed as Ear Trumpet adds a new pop-up near the volume control on Windows 10 which lets you control the volume for each apps.
Unfortunately enough, the app doesn’t replace the existing voulme control on Windows 10, but it’s still much better to have the ability to manually control volume for each apps. If you’re using Windows 10, you can grab the app here!
source:microsoft-new│via:rafael rivera
« Last Edit: July 12, 2015, 05:28:21 AM by javajolt »
