Author Topic: Office Tabs Free Download for windows 8  (Read 1684 times)
« on: June 21, 2012, 03:02:51 AM »
New version! - Office Tabs is a powerful office addin to view, edit and manage documents, workbooks or presentations etc via a Tabbed View in Microsoft Office 2003, 2007 and 2010. Microsoft Office has not supported tabbed view by itself yet. Office Tabs solves this issue. With Office Tabs, you can manage multiple documents within a single window easily and quickly.
 It works with all editions of MS Office: Enterprise, Ultimate, Professional Plus, Professional, Standard, Home and Business (Small Business), Home and Student...
The software includes three components: Office Tabs for Word, Office Tabs for Excel and Office Tabs for PowerPoint. It is fully free for home use (personal non-commercial use).
 Save All in One Click - Save All Documents, Close All Documents, Close Other Documents, just in one click! If you have opened multiple files, you don't need to save and close them one by one, just click "Save All" from the context menu and all files are saved. Want to close all opened files? Simply select "Close All” and all files will be closed.
Easy-to-use - Tabbed document interface lets you open multiple documents to be contained with tabs in a single window. Each document appears as a new tab in a tabbed window (not a new window) and can be accessed in one click. This feature conducive to quick and easy to improve your work efficiency with Microsoft Office Word, Excel and PowerPoint.
Useful Context Menu - Right-click on a tab or tab bar to accesses the Tab/tab bar context menu. Office Tab also combines some common command items of Office, that let you access those items more quickly.
Customize Tab Appearance - The colors of tabs and the tab bar are customizable. There are 11 styles of tabs for using. The font style and length of the name on each tab can be customized based on your preference (to apply the changes, you need to close and restart Ms Office applications).
Easily Rename Files - If you want to rename a file, there is no need to open the "Save As" dialog to rename a file. Just click "Rename…" from the context menu of the tab and enter the new file name; the file name will be changed. If you want to save the file into another folder, just access the "Save As" from the context menu.
Full Document Name - Without the Office Tab, if the document name is too long, the Windows taskbar can only display a small part of the document name. With Office Tab, the tab can display the whole document name on the tab bar no matter how long the documents name is.
Move Tabs - Tabs can be moved and dragged conveniently and switched by using mouse. You can activate a tab by pressing Alt + N (N stands for the Tab order "1, 2, 3…").
High Performance - Bases on standard Microsoft Office Add-in technology, no impact on Office performance and with extremely small file size.
